Connect object to sensor
Is it possible to connect a gdl object to live data from a sensor? How?
7 REPLIES 7
No not directly and not live that I know of.
I guess it could be done if your sensor can output data to a text file and then the object could read that text file (every time you rebuild and regenerate or open the object settings).
It would not be live and the object could never read the file while the sensor was writing to it.
So that is probably not a good solution.
Maybe with an add-on it could be automated a bit more but I think data would still have to go via an external file.
You have my interest.
What could you possibly want to do this for?
I am looking for for good solutions for FM use. We have a building with a lot of sensors that we Whould like to be able to read in the in the Bim.
Any segestion whould be mutch appreciated...
Aaron Bourgoin
via the Grasshopper Connection perhaps? There are GH components that interact with sensors.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Thank you very much for the reply. I would definitely try grasshopper.
Aaron Bourgoin
Keep us posted about this. I'm interested in learning more about what and how you're doing this.
MacBook M4Pro
Rhino 8.26 Mac
MacOS Tahoe 26.2
Will do...
I am also curious about this capability...
