2010-08-19 01:27 PM
2010-08-19 11:33 PM
2010-08-20 12:09 AM
velletti wrote:I've automated this process using the API, but only because it had to be done for literally thousands of drawings - probably not the kind of solution you're looking for.
How can I convert 2D drwgs. to objects in Archicad.
I have plan, front view and elevation for a Plane in 2D but I want to convert in a new object to use different views (elevation, front, plan) with the same object. GDL
2010-08-20 05:25 AM
2010-10-23 11:01 PM
If you're doing it manually, you could import each drawing in turn and paste it into the 2D section of the object. Make sure that each is on a different layer in the object, have a parameter to select the required view, and use fragment2 to draw the relevant layer.I am trying to do the same thing.
