2017-12-13
11:35 AM
2025-08-06
05:13 PM
Aruzhan Hamar
2017-12-14 01:23 AM
2018-01-08 11:04 PM
2018-01-09 05:48 AM
DrWho wrote:We won't know what Darwinland wanted unless he/she posts back...
I think Darwinland is talking about being able to copy a single item from one story to many different stories. If that is the case then I am with him. Nothing worse than designing a 20 story building and discover that you want to make a design change that affects all the stories (say to add a wall and door). The current method would be to create the new items on one floor, highlight and copy the objects and then open each floor, one by one, and paste the objects to each floor. I find it very tedious ....
2018-01-09 11:37 PM
2018-01-10 01:26 AM
2018-01-10 04:58 AM
The drawback to hotlink modules is when you want to change several but not all instances on each floor. You could create a new hotlink module with the changes required but to implement the changes will require the user to delete all of the unwanted original modules on the required floors and then paste the new module to the associated floor/story by pasting one floor at a time.There's no need to delete and individually replace the required modules. You should be able to select the instances that need to change, and replace the referenced module under the module settings. As long as the origin of the replacement module is the same, it should come in at the same locations.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
