Craftsman Column GDL
Does anyone know where I can get a craftsman column GDL? I'm mainly interested in the squared tapered column, either with or without a base.
12 REPLIES 12
Rob
In the case of craftsman details, considered that they are constructed of wood. So I have built those columns using complex wall profiles.
ehm....morph?
::rk
gpowless
I use complex walls because I can also model the plynth & trims below it (including banding & rowlocks in the coursing). Structurally I use a common column for the centre core.
Intel i7-6700@3.4GHz 16g
I dug up the current copy and the macro it calls and combined them into one library container. AC 12 and up.
I don't have the animated gif showing the versatility, and certainly it could be spiced up with more interactive editing hotspots, etc., but on "as-is" I can send you a link for the download. I didn't follow objectsonline closed shop.
maybe a simple paypal?
