Create Subtype Template?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-03-19 04:57 PM
2004-03-19
04:57 PM
If anyone knows that, maybe they can also point me at the tip about using subtypes to copy parameters to other objects. Or did I dream that?
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-19 05:33 PM
2004-03-19
05:33 PM
James wrote:Re-purposing a screenshot ... so ignore the red circles... but notice at the top of the GDL window that there is a check box for "Template". Click that and save your object and it becomes part of the template hierarchy whenever it is loaded.
I'm losing it...I know I've created subtype templates before, I can see them, it looks like I even created some by accident. Can't find it here or in GDLTalk.
It won't let you copy parameters to other objects so much as it will add the template object's parameters to the available parameters of another object whose subtype is switched to the new template object. Whew?
Of course, be sure to select the desired template for YOUR template before saving so that it inherits as many useful parameters as necessary and is placed in the correct position in the subtype hierarchy.
HTH,
AC 28 USA and earlier • macOS Sequoia 15.3.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-19 05:52 PM
2004-03-19
05:52 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-03-19 08:59 PM
2004-03-19
08:59 PM
James wrote:
As I say when my almost-3-year-old says she can't find something, 'are you looking with your eyes or with your mouth?'
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-08 11:03 PM
2004-04-08
11:03 PM
On this topic.
I have a question about using templates and how to edit them for global use.
I have a template from a library set I puchased. I do not like some of the default material choices.
So I found out where the template was located at and went to set it. Then it seems this template is based on another. When I tried to look for this one, "Equipment Element", I found that I could not find a simple GSM file. It was a plugin. As so, I could not edit this template. Does anyone have a suggestion about changing a template.
I am sure you are going to say don't do it. But I hate going through every part to change the materials and saving them.
How do I determine what is from one template and another template??? Could I use my own template instead?
TIA.
TIA.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
