2026-01-27 06:11 PM
Starting with Archicad 28 (and now 29), when I Share a .pln file to change it into a Teamwork file, several of the objects (typically doors and windows) suddenly disappear, insisting that they are missing from the applicable Teamwork library packs.
These are the standard objects that I can clearly see in the local versions of the packs. The switch from the local / .pln libraries to the BIMCloud libraries seems to be the culprit, but try as I may, I can't bring the objects back.
Are the BIMCloud libraries somehow missing objects and / or corrupted? If so, how do I replace them with the most updated iteration?
Any help is greatly appreciated.
Operating system used: Windows 11 25H2
2026-01-27 08:16 PM
Can you try this:
1. Upload all libraries that you link to your Solo PLN file to the BIMcloud server.
2. Relink all libraries from local storage to BIMcloud, so all libraries are loaded from the BIMcloud server (all are BIMcloud libraries).
3. Share the project as Teamwork file.
2026-01-29
09:00 PM
2026-01-30
04:21 AM
It doesn't let me overwrite the current BIMCloud library packs with those from the PLN.
Uploading the linked libraries doesn't convert them to BIMcloud libraries. It's just storing PLN libraries online.
Even if I put the uploaded files in the main BIMCloud 'Libraries' folder, it's not a BIMCloud library, and can't be mapped.
Uploaded PLN libraries appear to be a different format, and won't allow themselves to be used as BIMCloud libraries.
2026-01-29 09:17 PM
I'm now trying the recommendation found here...
https://support.graphisoft.com/hc/en-us/articles/37260369320593-Archicad-library-package-shows-has-w...
It appears to be working, updating the BIMCloud libraries directly through Manage BIMCloud libraries.
This error means your local machine is missing a required Library update.
If you updated library packages but did not upload the updated version to the BIMcloud, the packages on the server remain outdated.
2026-01-30 05:06 AM
Your BIMCloud library version might not have been up to date? The first libpack update was not reverse compatible, so if one source updated, every source needed to be updated else you would get missing objects. Not sure if the second one was the same, or if they have some how re-implemented it to be reverse compatible.
Ling.
2 weeks ago
This is ridiculous that we have to go through this. So I, and EVERY damn collaborator of mine that I work with, have to individually update dozens of library packs every time they update a library?
Who's idea was it to go to this method in v28 when this new library method was first implemented?
2 weeks ago - last edited 2 weeks ago
I believe they have updated BimCloud to allow you to mass update the libpacks. I have not tested it though as I am still using the AC28 libpacks due to missing features that I use in the AC29 ones...
If you are working on a project that is intended to be TW, you could always just link it to the TW libraries by default? In that way it will still be using the same library update or not.
Ling.
Interesting work-around. Thanks for the tip. But, why did they take something that works, and then break it?
As for library pack to BIMcloud library updates en masse, the option grays out when I select more than one library pack in the Manage BIMcloud Libraries. I still contend that if we have to go through this exercise every time they update a library, it will not be acceptable.
---EDIT---
It appears if you choose the first option to "upload a local library..." it allows you to choose multiple ones and it will update its corresponding library packs on the BIMcloud.
But still...
