Curved Base Battening Item?
does anyone know of library item that will allow me to do this battening with a curved bottom?
or have one that they are willing to share??
or know if theres one in the standard library that i just cant seem to find??
NOTE: i do not want to do this with complex profile as i have about 40 to do and there all different width openings.
thanks
gene
5 REPLIES 5
Gene
I had to do something very similar last week and the quickest solution I found was Fence Vertical 13 in Fences and Railings 13 (ArchiCAD lib) and used a very quick custom profile (drawn between the posts in elevation) and then did a quick SEO.
was quick enough to do the fencing around 13 units.
cheers for that. ill give it a go
Personally, I would just draw an arc (dashed) with a note saying "to be removed".
Erika Epstein
Kristian wrote:
Gene
Great solution! I find drawing an element once as a 3D object is the best solution.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
needs to show up in 3d tho. and they're staying.. there extending the house and more are being added in
