‎2007-02-27
08:59 PM
‎2023-05-24
11:02 AM
Rubia Torres
‎2007-03-04 10:31 PM
IF gs_typ_size > 0 THEN PARAMETERS A = gs_typ_sizeYou probably already know that the parameter names have to match for the elements to schedule together.
‎2007-03-05 05:54 PM
‎2007-03-06 05:20 PM
B wrote:There is a trick of adding a dynamic hotspot to switch the door between the two rooms, but it is a bit of a kludgy workaround. Unfortunately there is an execution order problem which prevents reading the results of the Zone Relations request function into a parameter - thus making it useless for door schedules.
Do you know if anyone has found a solution to this other than just manually entering the room numbers into the door id and not scheduling the zone ?
‎2011-12-04 06:01 AM
