‎2012-10-02
09:56 PM
‎2023-05-24
10:13 AM
Rubia Torres
‎2013-07-17 01:52 AM
‎2013-07-17 01:57 AM
‎2013-07-17 08:32 AM
vfrontiers wrote:I totally agree.
I have three projects that need the same door panel (which, btw, should be a STANDARD OPTION / High and Low Louvers).....
Why can I NOT save to my LINKED library? Am I the only one who feels this way? (wouldn't be the first time!)...
‎2013-07-17 06:40 PM
vfrontiers wrote:Totally have the same experience. For me, I will just modify the part and save into the "embedded library". Then later on will export out to the hard drive, then refresh the bim server library.
Pet Peeve #444
Don't know if any of you can corroborate this, but opening and working on objects in TEAMWORK file slows down to 1/10 or worse the operating speed of a PLN file...
I should mention that the LEAF is available in the PLAN file version... my tactic has been to create a PLAN file for OBJECT EDITING... link to libraries that are the ROOT of the BimServer Library.... Make all changes there, then REFRESH the BimSERVER libraries just to avoid this slowdown..
Please, someone back me up here???!!!!!! or suggest an alternate method of creating parts to be used in all my projects....
