2006-10-04
04:36 AM
2023-05-24
12:06 PM
Rubia Torres
! Document name: ! ! ! Name : 3 Pier Corner Column.gsm ! Date : Tuesday, 3 October 2006 ! Version : 10.00 ! Written by ArchiCAD ! mulx A/ 0.6484375 muly B/ 0.64453125 mulz ZZYZX/3.042999982834 sprism_{2} mat_1, mat_1, mat_1, 9, 0, 0, 1, 1, 0.858, 0, 0, 0, 1, 0, 0, 0, 57211.44362962, -33052.06768026, 15, ind(material," Paving - Brick"), 57211.41362962, -33051.93768026, 15, ind(material," Paving - Brick"), 57211.81362962, -33051.93768026, 15, ind(material," Paving - Brick"), 57211.92362962, -33051.82768026, 15, ind(material," Paving - Brick"), 57211.33362962, -33051.82768026, 15, ind(material," Paving - Brick"), 57211.33362962, -33052.17768026, 15, ind(material," Paving - Brick"), 57211.57362962, -33052.17768026, 15, ind(material," Paving - Brick"), 57211.58362962, -33052.06768026, 15, ind(material," Paving - Brick"), 57211.44362962, -33052.06768026, -1, ind(material," Paving - Brick") body -1For instance here, this is code from the 3d window of my object and i saw that 0.858 value is the height so i could replace that with a param, but it doesn't effect any other object so i guess you would need to group all these together. That begs the question of how does it then only change this objects height and not all objects of the group..
2006-10-04 09:21 AM
2006-10-04 06:18 PM
2006-10-06 08:01 AM
2006-10-06 12:37 PM
2006-10-11 08:14 AM
2006-10-13 03:25 AM
