‎2006-10-04
04:36 AM
‎2023-05-24
12:06 PM
Rubia Torres
! Document name:
! Name : 3 Pier Corner Column.gsm
! Date : Tuesday, 3 October 2006
! Version : 10.00
! Written by ArchiCAD
mulx A/ 0.6484375
muly B/ 0.64453125
mulz ZZYZX/3.042999982834
sprism_{2} mat_1, mat_1, mat_1,
9, 0, 0, 1, 1, 0.858, 0,
0, 0, 1, 0, 0, 0,
57211.44362962, -33052.06768026, 15, ind(material," Paving - Brick"),
57211.41362962, -33051.93768026, 15, ind(material," Paving - Brick"),
57211.81362962, -33051.93768026, 15, ind(material," Paving - Brick"),
57211.92362962, -33051.82768026, 15, ind(material," Paving - Brick"),
57211.33362962, -33051.82768026, 15, ind(material," Paving - Brick"),
57211.33362962, -33052.17768026, 15, ind(material," Paving - Brick"),
57211.57362962, -33052.17768026, 15, ind(material," Paving - Brick"),
57211.58362962, -33052.06768026, 15, ind(material," Paving - Brick"),
57211.44362962, -33052.06768026, -1, ind(material," Paving - Brick")
body -1
For instance here, this is code from the 3d window of my object and i saw that 0.858 value is the height so i could replace that with a param, but it doesn't effect any other object so i guess you would need to group all these together. That begs the question of how does it then only change this objects height and not all objects of the group.. ‎2006-10-04 09:21 AM
‎2006-10-04 06:18 PM
‎2006-10-06 08:01 AM
‎2006-10-06 12:37 PM
‎2006-10-11 08:14 AM
‎2006-10-13 03:25 AM
