Custom Door handles
Some door types in AC 11 library allow custom door handles (commercial doors), others do not (storefront doors). How could I add the ability for a custom handle to the storefront doors?
6 Replies 6
I would also like to add a custom door handle to a storefront door.
Have you had any luck doing that so far?
Peeter
Erika Epstein
When you create your new hardware choose
Under Model Element
Custom Component Template
Custom DW Hardw Component
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yes
But if I wish to use the door "D1 storefront 1 11" in AC 11 for example, selecting a custom door handle is not an option.
Peeter
Hello!
I would like to use a custom door handle but I am completely lost with this issue.
The handle must be created as a GDL object and placed in library, isn't it?
When creating the object, the "custom door handle" must be selected in "subtype".
And then, in Internal Door Settings > Door Panel > Handle > Custom Handle, it must appear.
Do you know of any examples of GDL door handles to donwload? I haven't found any.
Thank you!
I don't know if this is supposed to work like this or not.
I guess it should but I just don't know if it would appear as a selectable Door Handle in the Door Settings Dialog.
If you model something, select it and use the File\Libraries and Objects\Save Custom Component command and save with the Custom Door Handle option, it should appear as a selectable option.
Maybe you could do that and later modify the 3D Script of what you saved this way.
Thank you Laszlo, is worth to investigate it. In case I arrive to any solution, I will let you know.
