Custom Door handles
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-08-29
05:36 PM
2023-05-24
11:01 AM
Rubia Torres
2007-08-29
05:36 PM
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-02-25 12:54 PM
2008-02-25
12:54 PM
I would also like to add a custom door handle to a storefront door.
Have you had any luck doing that so far?
Peeter
Peeter
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-02-26 05:31 AM
2008-02-26
05:31 AM
When you create your new hardware choose
Under Model Element
Custom Component Template
Custom DW Hardw Component
Under Model Element
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-02-27 09:53 AM
2008-02-27
09:53 AM
Yes
But if I wish to use the door "D1 storefront 1 11" in AC 11 for example, selecting a custom door handle is not an option.
Peeter
Peeter
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-24 01:35 PM
2011-04-24
01:35 PM
Hello!
I would like to use a custom door handle but I am completely lost with this issue.
The handle must be created as a GDL object and placed in library, isn't it?
When creating the object, the "custom door handle" must be selected in "subtype".
And then, in Internal Door Settings > Door Panel > Handle > Custom Handle, it must appear.
Do you know of any examples of GDL door handles to donwload? I haven't found any.
Thank you!
Thank you!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-25 07:35 PM
2011-04-25
07:35 PM
I don't know if this is supposed to work like this or not.
I guess it should but I just don't know if it would appear as a selectable Door Handle in the Door Settings Dialog.
If you model something, select it and use the File\Libraries and Objects\Save Custom Component command and save with the Custom Door Handle option, it should appear as a selectable option.
Maybe you could do that and later modify the 3D Script of what you saved this way.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-26 08:40 PM
2011-04-26
08:40 PM
Thank you Laszlo, is worth to investigate it. In case I arrive to any solution, I will let you know.
