4hotshoes
Custom Door will not change surface material
I have tried many different way to change the custom door I created to a different surface than what it was created in. How is this done?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
6 Replies 6
This has cropped up a couple of times recently.
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=61612
It can be scripted but I wouldn't bother.
The materials you use when you create the custom door is what you are stuck with.
I haven't tried using the surface painter tool.
Maybe that will help to swap the surfaces.
Guru
Custom Door or Custom Door Leaf?
For a Custom Door, it would depend on if the material assigned to it is linked to a visible Parameter.
For a Leaf, you are unable to unless you duplicate the entire door hierarchy and add in your leaf's material Parameter into each sub-object. As Barry has mentioned, this is most likely not worthwhile.
Ling.
4hotshoes
It is a leaf. I wish I had known I could not change it. I did not save my work on it, because I did not know where I could save it. Is there a way to copy the leaf out as a slab, edit and save?
Todd Oeftger
vistasp
You might want to save such parts to a special layer or storey so that they can be modified as and when needed. Just make sure they don't get scheduled!
For now, you can convert a copy of the door to a morph, remove the extraneous parts, change the surface as needed, and re-save it as a door leaf just as you did earlier.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Stress Co_
When I create a custom door leaf,
I use a custom Surface material
(generically named, for example: "Front Door")
I can change the surface in "Surface Settings"
without having to to open/modify/re-save the the original
parts I used to create the leaf.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Guru
Now if only there was a way to copy settings between surfaces...
