2024-09-25
07:41 PM
2024-10-02
12:17 AM
Witch is the best way to create an sliding door with 6 leafs?
Create ir as a new custom door or create only the leafs?
Solved! Go to Solution.
2024-09-26 03:34 AM - edited 2024-10-02 05:04 AM
You have to create a custom door (including the frame) object.
Creating just the custom leaf (or 3 or 6 leafs as one leaf), will simply replace the door leaf used in a door frame.
The leaf will be resized to suit the frame,
You can resize the frame opening width of course, but it won't add extra sliding tracks.
2024-09-26 05:50 AM
There is a sliding door in the CI Essential Library that does up to 6. Was that a AUS/NZ thing? Does it still come with a Select (or what ever they renamed it to) Plan?
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2024-09-26 06:54 PM
where do i get this library?
2024-09-27 06:14 AM - edited 2024-09-27 06:16 AM
Still there and under the same name in AC27.
2024-09-27 06:15 AM
CI is Central Innovations, look them up.
