2024-07-24 01:08 AM
Hello!
I created a custom title block to use with my views on layouts.
However, it seems to be scaling itself and not be consistent with 3.00 text I wished. May I please have some help resolving this issue.
I wanted to create a title block instead of placing a text box underneath to automated safety.
Please see attached a screen shot of two views on layout with the same title block and text not being the same size:
Thank you in advance! Peggy
Operating system used: Mac Intel-based
Solved! Go to Solution.
2024-07-24 09:20 AM
This is a problem noted on the Archi-CADlink forum
Solution open the object and add this line in the 2D script
FRAGMENT2 ALL,0
2024-07-24 03:02 AM
How did you create the drawing title?
Is it just the one title or have you created 2 different ones with different sized text?
2024-07-24 06:51 AM
Hi Barry,
I created just one title.
2024-07-24 08:10 AM
So you just typed some text and then selected it and "Save Selection A Library Part" > Drawing Title ?
Then you used that drawing title object in the drawing settings?
If so, then I just did the same and the text is a fixed size as it was saved and I can't change it.
So I am not sure why it would be different for you.
2024-07-24 09:20 AM
FRAGMENT2 ALL,0
2024-07-25 01:05 AM
Hi Barry,
yes, that's exactly what I did! I haven't had problems before doing it this way, so it's very confusing!
But thank you for your help! It's very much appreciated!
2024-07-25 01:11 AM
Amazing! That fixed it!
Thank you very much Yves.
