Custom Zone Stamp
Hi, I wanted to ask for a clean way of creating a custom zone stamp.. I want to make sure I dont create on and place it or save it in a way that would damage the default zone stamp... I am building an office standard library to be loaded along with the default Archicad and the project specific libraries...
Can someone please post the process for saving a custom zone stamp? i can figure our how to add subtract parameters from there (i think).
Thanks!
1 Reply 1
On the Floor Plan, select the Zone Stamp you wish to use as a basis for your custom Zone Stamp and use the Open Object command.
Then immediately save it under a new name and then you can start editing. It will not cause any change in the original Zone Stamp library part.
