Customed 2D OBJECT not showing in schedule
Llian
I've saved a customed 2D light fixture as an object and have given it a ID but it is not showing in the Lighting Schedule. What am I missing ?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC28 USA | Windows 10 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
You can save your object with the subtype of the objects being called by the schedule. (see Attached). This way the object will have the parameters that are listed in the schedule.
I think you could instead use the Scheme settings of the schedule to bring in your object. You would have to manually add the parameters that the schedule is calling for so it could find them.
