Customize Library Manager?
I'm trying to load gdl-objects from a spesific place in my filesystem.
I'm using Library Manager. Every time I've loaded a bunch of objects, I loose the spesific position in the filesystem. I wonder if it's possible to customice Lib.Man. so I can keep this position during the sessin and also store it with the project template, so I start at the same position every time I enter lib.man. from projects based on that template?
1 REPLY 1
I do not think this is possible but there is the History tab page of the Library Manager which list the latest locations you accessed previously. That's about all that can be done there.
