Customized Door Leaf Missing
Hello all!
This happened only after opening the file many times. The frames are okay but the leaf is all gone---not only transparent. I hope someone has a solution for this. Thank you in advance!
5 Replies 5
I would think this is because the custom door leaf objects are no longer in your loaded or embedded library.
The library loading report should be listing them as missing objects?
It's not being recognized as missing by the Library Manager. I tried using the Tool Settings Dialog Boxes and made the Model in the Door Tool visible but it still hasn't made any changes..
Were the door leafs created with a transparent material?
Or is there a Graphic Override in use that is overriding the material?
Or possibly a Renovation Filter hiding them?
I think I am out of ideas now.
It's okay now! It seems like it just needed to be reloaded, NOTHING is MISSING! From the Door Schedule, I selected the door (perfectly fine not missing anything at all) and went to 3D view (which shows the missing leaf) then I viewed the settings (CTRL+T), did nothing, and clicked OK, then it showed up. Thank you for responding to this!
Guru
Is the custom door leaf drop down showing up blank? If so, have you duplicated any of these custom door leafs? Check within the door leaf objects themselves and ensure that the coll_guid and coll_name are blank. I had an issue where if a door leaf object had those parameters assigned and where duplicated, the file would fail to generate the Door Panel Collection the next time it was opened. This results in the door leaf not generating. Related thread.
Ling.
