2011-06-30
09:09 PM
2023-05-24
12:36 PM
Rubia Torres
2011-06-30 09:38 PM
Mats_Knutsson wrote:The modular joinery object would do everything except the segment where the wall intrudes into the bounds of the window. The modular joinery allows you to independently specify what every segment of a unit is, including "Door", "Window", "Panel" - but what if "Wall" was added to the list?
I'm trying to make a really simple door-window combo for early stages like attached image (elevation). I need to control reveal sides and reveal top separately and also the position of the post. I tested different AC standard windows and also the modular joinery object but I'm not where I want to be yet
2011-06-30 10:26 PM
Ralph wrote:Hi Ralph,Mats_Knutsson wrote:The modular joinery object would do everything except the segment where the wall intrudes into the bounds of the window. The modular joinery allows you to independently specify what every segment of a unit is, including "Door", "Window", "Panel" - but what if "Wall" was added to the list?
The attached image illustrates how the selected segment is set to "Panel", but if set to "Wall" would fill that area with the surrounding wall. I'm in the process of updating the object, so let me know if this would suit.
2011-07-01 04:28 AM
