Designer furniture
Hello.
Does anybody have eames plywood lounge chair, bertoia side chair and george nelson bench I could download for a project I am doing?
10 Replies 10
I doubt you'll find anything that specific, but can you upload images so we can see what you're after?
nelson bench
bertoia chair
eames chair
David Maudlin
neutra.des wrote:
nelson bench
This bench could be made with 3 parts in ArchiCAD, then grouped or saved as an object:
1. Make the seat from a slab with holes. One hole can be copied or multiplied.
2. The vertical part of the legs from columns that are sloped.
3. The horizontal part of the legs from slabs or beams.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
The Eames plywood chair (and lots of other cool stuff) is available in Sketchup format at the warehouse.
sketchup.google.com/3dwarehouse/
You will have to open it in Sketchup Pro and save as 3DS or DWG (OBJ and VRML might work also). The add-on for 3DS import is available as a goodie (go to the ArchiCAD help menu and it will take you to the web site to download).
I don't know how good the translation will be. I've brought in 3DS to ArchiCAD with great success but don't know how well Sketchup puts out.
Ahem, Matthew, there is the
<<google earth plugin>>
(Or is not available to Macs?).
It opens up a whole new world for AC in terms of dumb* objects to insert in models to dress them up, and works well too! Only issue I've noticed is that the polygon count may kill you (one of the many reasons we use Artlantis).
A while ago we did work at a marina - boats that would have previously cost us a fortune are now free!!!! And there is more choice. And if you cannot be bothered modelling with GDL in AC - model in Sketchup and import.....
*=non-parametric
owen
(Or is not available to Macs?)...
nope
GS Aust had a 'technical issue' when it came to demonstrating that feature to our office during the AC11 launch
AFAIK the lack of a Mac plugin for AC is a Google issue, not Graphisoft.
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Thanks for your help everyone.
Matthew, I have got as far as downloading sketchup and saved the eames chair as a 3DS. I just don't know how to open it in archicad 10 any ideas?
