The question is what is your scale ?
If you print a 1/50 view you can use the most detailed model view into "Documentation/Model view/Model view option"
If you want to print a 1/20 or a 1/10 view your have to use your manufacturer dwg on a worksheet or with the Patch tool (documentation / Annotation / Create Patch)
Christophe - FRANCE Formateur Archicad indépendant à NANTES Archicad 15 to 29 FRA FULL
