2007-10-31
09:22 AM
2023-05-24
12:03 PM
Rubia Torres
2007-11-14 07:50 AM
2007-12-14 06:40 AM
David wrote:David what effect does this have on any other markers you've already placed in this or other projects? Will they change now? And does the marker have to be saved out into a separate library?
You can open the Marker object in the Library Part Editor and set all of your preferred parameters. Once you save and close the Object, the Marker settings will default to your saved configuration.
2007-12-14 04:29 PM
Link wrote:Just changing the defaults won't alter existing instances (you can still turn that on if so desired - though it is very dangerous to do so). Of course, altering the code in any way will affect all instances of the part in all files where it has been used.David wrote:David what effect does this have on any other markers you've already placed in this or other projects? Will they change now? And does the marker have to be saved out into a separate library?
Link.
2007-12-15 12:27 AM
Matthew wrote:Of course, this is what I meant.
