Door Marker Glitch
I have found that in AC 13 that if I have my door marker ID Text Orientation (under marker settings>marker geometry) set to horizontal instead of standard the text becomes offset out of the marker. If I set it to standard, no problem. This only seems to be a problem with Door Marker 13, If I use Door Marker 11 it seems to be O.K.
Has any one else noticed this, and if so is there a fix?
I have attached a screen grab for reference
13 REPLIES 13
Erika Epstein
With the file open SAVE AS and choose file type pla.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Oh, duh. An archive project.
O.K., I have tried to attach it as a file in a reply but it does not seem to be working. Any suggestions?
Erika Epstein
email it with the attached file, zipped, to
techsupport@graphisoft.com
include your name, firm name, and Graphisoft ID number.
Also attach your description of the problem as you described here in this thread.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
