‎2008-10-23
11:05 PM
‎2023-05-26
11:29 AM
Rubia Torres
Solved! Go to Solution.
‎2008-11-12 04:33 PM
Jooogyerek wrote:
4. When writing text it is possible to set the background fill underneath it, which (may) cover the less important lines and objects that can disturb the legibility of the text. Is it possible to set this kind of filling behind the dimension text too?
5. Since I made mass changes in the setting of the doors, more precisely with the thresholds I'm getting this error message(attached picture) during some procedures. For example, when I'm creating zones in a room in which the above mentioned door types are present as well as when I'm trying to generate the front-view. Till now it hasn't caused significant problems, but I'm curious about the cause of the problem and about the way to solve it.You have probably created a body in which two nodes are at the same position (e.g. two consecutive nodes of a SLAB or similar) so it cannot be generated in 3D. It is also possible that the dimension of some element is zero which gives similar result hen AC tries to generate its 3D.
‎2008-10-24 01:09 PM
‎2008-10-24 01:19 PM
Jooogyerek wrote:You should do that in the Work Environment Dialog. The Palette Scheme is the one that stored the position and on/off state of toolbars and palettes.
My first problem is that I want save my profile settings somehow, so I don't have to set-up the toolbars always. I looked for the option but I didn't find and the template files don't saves it. [/img]
‎2008-10-24 03:27 PM
‎2008-10-24 04:44 PM
‎2008-10-24 08:00 PM
‎2008-10-24 08:34 PM
‎2008-10-24 10:57 PM
‎2008-10-25 06:20 PM
‎2008-10-25 06:39 PM
