Door Window Marker
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-03-08
10:06 PM
2023-05-26
11:43 AM
Rubia Torres
2005-03-08
10:06 PM
I see a "load other window-door marker" option but it leads nowhere.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-08 10:45 PM
2005-03-08
10:45 PM
Can you be a little more specific? Where are you seeing these prompts?
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-08 11:27 PM
2005-03-08
11:27 PM
Window (or Door) Selection Settings/ Dimension Marker/ Window Marker pull down menu. Different marker types can be selected, and there's a "Load Other Door-Window Marker" selection.
So I'm figuring there's a way to save all my custom edited selections for the marker as a sort of favorite. That's without saving the window itself as a favorite—basically I want to use the same marker with different windows without having to edit a dozen or so parameters.
Thanks!
Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-09 10:46 PM
2005-03-09
10:46 PM
If you go to File\GDL Objects\Open Object by Subtype, you get the Dialog in the attached image.
Here you can find the Window-Door Markers, and you can open them for editing, Save as another name to any place you want, and you can modify that.
If you save it into a loaded library you will have in the list of selectable Window-Door Markers, so you don't have to search for it with the Load other Window-Door Markers command.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-10 02:17 AM
2005-03-10
02:17 AM
Awesome—Thanks!
