Patrick M
Door leaf does not match door size
whats the deal? door is set to 2'-6". Door opening is 2'-8", door leaf is 2'-4"... I have a 1" gap between my door and the frame. I'm not seeing any setting to undersize the door to the frame. anyone run into this before?
3 Replies 3
Guru
What does the frame tab show?
Patrick M
nothing out of the ordinary... I just rebuilt them from out of the box defaults... just a weird glitch, injecting one door type into another
Guru
Injecting settings can give odd results if the source and host do not have identical parameters (not values). I swapped one of my custom sliders which was based GS macros into a GS slider (libpacks broke my custom one...) and the panels when set to fully closed only covered half the opening...
