Tom Krowka
Door leaf object-materials
Have created a new door leaf; able to insert the leaf in a door and place on plan. However, the leaf materials will not change per the model attributes settings, but stays with the material it was created with. Is there any way to make the leaf material changeable, or do I have to create a new leaf for each different material used?
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
Basically the custom door leafs use the materials set when they are created and they can't easily be user defined.
It is possible but I am not sure it is worth it.
It has been discussed before here ...
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=27956
