Door leaf shown as one line in plan
Sara Davoudi
I'm using archicad 26 and trying to get my door leaf shown with two lines. Even though I changed the Level of detail for the door to 1:50, still I get one line. I also changed the setting for model view. How can I solve this problem?
I'm using a German version but I hope the pictures are graphically understandable.
Bildschirm_foto 2024-01-17 um 11.40.54.pngā€ƒ
ā€ƒ
11 REPLIES 11
So not only are the door and window objects different between language versions, the Model View Options are different as well.
This does not make things easy for a software that is used internationally.
SaraD
I think the only way to show the door leaf open with 2 lines in the German version is to use a door object from external libraries.
