We value your input!
Door leaf shown as one line in plan
Sara Davoudi
I'm using archicad 26 and trying to get my door leaf shown with two lines. Even though I changed the Level of detail for the door to 1:50, still I get one line. I also changed the setting for model view. How can I solve this problem?
I'm using a German version but I hope the pictures are graphically understandable.
11 REPLIES 11
So not only are the door and window objects different between language versions, the Model View Options are different as well.
This does not make things easy for a software that is used internationally.
SaraD
I think the only way to show the door leaf open with 2 lines in the German version is to use a door object from external libraries.
