‎2025-01-09 09:56 AM - edited ‎2025-01-09 10:11 AM
Hello, I have the next issue: I have an apartment module that I use in a flat layout in different positions (rotate and mirror). I want to use marker on doors, but I need next to the ID to write the door open orientation (left or right). If I put it in the ID (manual) it will not be accurate for when the module is mirrored. Can someone help with a solution, I tried to find some parameters to add, but no orientation. Only in Find and in Schedule I can separate by left or right.
‎2025-01-10 05:32 AM
The door marker is a scripted GDL object, so unless it allows you to show the orientation, you will not be able to.
Rather than creating your own marker, why not try an autotext label.
‎2025-01-16 03:12 PM
Thank you for the tip, it is true that with autotext label is working. Now, as I researched this forum I found your solution for change the text for L(left) and R(right) in library - compatibility option, but I don't understand why with my archicad it doesn't work, nothing changes. I create a new door with these changes and use it in the project and the text in the label remains the same L,R.
‎2025-01-17 02:58 AM
If you are using version 28 with the Global Libraries, I think things may be a little different.
I believe it uses your localisation as stored in your template (file) rather than the object itself.
I haven't experimented with it so i am not sure.
This is were I have seen this mentioned...
So altering an object may not alter the results you see.
Again I am not sure as I have not tried in 28.
I know you can set the language preference used in your file (template) ...
But I am not sure if you can now alter the orientation (L/R) that is saved in the objects.
I am not quite sure how it all works now.
