Doors are just flat plane in 3D
Hello everyone,
Basically my sliding doors and every other door are flat and look grey. In 2D mode they exist, they look alright as well, i can even slide the door, but theres nothing similar to a door in 3D. I searched for a solution, I couldn't find any, so if theres a Solution to that, somewhere else I'd appreciate a link. Thank you in Advance.
Screenshots:
http://prntscr.com/svluj5
http://prntscr.com/svlxh5
Regards
~Black
Lingwisyer
Guru
Check your MVO settings, both the Global and if that does not fix it, the setting within each of the doors / windows themselves.
Ling.
Lingwisyer
Guru
Ling.
Ling.
Thank you got the problem solved, btw for people having the same issue you can find what he meant under documentation at the top.
