‎2025-07-05
11:50 AM
‎2025-07-05
03:13 PM
Good morning,
in a file I received from a friend, there is a strange behavior:
even selecting different materials in the doors, for the leaf, glass, jambs, the door is then displayed in 3d with a single material. As if there was a graphic overwrite, which instead I do not see in the list of overwrites.
The windows instead work correctly.
Do you have any idea what it could be?
Thanks for the suggestions.
Solved! Go to Solution.
‎2025-07-05 12:41 PM
Check the Model pane in the Door Settings, it may be set to Override Surfaces. If the Model pane is not visible, go to Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Door Tool and make the Model pane visible, it may be hidden in the default WE.
David
David
‎2025-07-05 02:04 PM
Thank you, solved, the model panel was not visible ! 😊
‎2025-07-06 12:35 PM
Good to know that worked, thanks for adding your signature.
David
