Cocodasty
Doors displayed with a single material
Good morning,
in a file I received from a friend, there is a strange behavior:
even selecting different materials in the doors, for the leaf, glass, jambs, the door is then displayed in 3d with a single material. As if there was a graphic overwrite, which instead I do not see in the list of overwrites.
The windows instead work correctly.
Do you have any idea what it could be?
Thanks for the suggestions.
Ac 27, win 11
1 Solution
David Maudlin
Cocodasty:
Check the Model pane in the Door Settings, it may be set to Override Surfaces. If the Model pane is not visible, go to Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Door Tool and make the Model pane visible, it may be hidden in the default WE.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
3 Replies 3
David Maudlin
Cocodasty:
David
Cocodasty
Thank you, solved, the model panel was not visible ! 😊
Ac 27, win 11
David Maudlin
Cocodasty:
Good to know that worked, thanks for adding your signature.
David
