Doors threshold invisible in core and schedule.
Hi
Is there a way to be able to se the threshold of doors in CORE plans and Schedule?
I always have to dray red lines in Schedule and line in CORE plan.
I know manny of you are going to ask why i want the threshold to be seen in CORE plan since it is a feature you want to be seen in Finish plan.
This just make it more easy in other aspects
6 Replies 6
These "Threshold" lines can be mimicked by using Wall contour Lines option that is available for most doors and windows. You can choose the Pen and Linetype.
So you will have to modify the Doors ( can be done all at once -if you're using the default library) and not the views.
oh, and the lines will show up in your schedules as well.
Regdards
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Hi
I have a lote of round walls
Is there now way to fix this in 3D script?
Are you saying you would like curved frames and doors to suit the curve of the wall?
Wouldn't you still use a straight frame or does your client have a lot of money for custom made curved frames and door panels.
Or am I missing what you are after?
Hi
No!!
The way "NandoMogollon" consist of showing the walline in the 2D plan.
I want to show the threshold of the door and if the wall is supposed to represent the threshold then it will be curved on a curved wall.
I want to show the threshold straight on round walls.
Is there no way to change the script of the doors so it will show the threshold in CORE and door schedule?
yep, modify the doors may be easy if you know some basics of GDL, and yes they will show up in your schedules, plans and 3D views
Nando Mogollon
Hi
Thank you very much for posting
I have been working in Archicad for 2 years and I dont know any basic of GDL.
I want to learn do you know any good tutorial that will help me with my problem?
Tank you ))
