Dorr Markers rotated 90 degrees
Dave Brach
When I place an associative lable for my doors, the number is rotated 90 degrees, and I can't figure out how to correct this. Can anybody help me?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
4 REPLIES 4
David Maudlin
Dave:
I was able to reproduce this bug by mirroring a wall with a labeled door, using the Label Door-Marker 15. There is code in the label for Wall_Direction that I think is supposed to correct for this. The only solution I found was to change the Label Rotation value (Label Settings > Symbol Label > Rotation Angle) to 90.01˚ (setting this to 90˚ does not work correctly).
It would help if you named the Label you are using, as well as added screen shots of the problem.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Dave Brach
Thanks, David.
I am using Label Door-Marker14. In my case, if I change the rotation to 270.01 degrees then it is correct. So that works but it's a little annoying.
Attached is a screen shot
David Maudlin
Dave:
I found this problem in plan, doors in walls running x axis are ok, doors in walls running y axis show the bug. Besides trying to correct the GDL code in the Label, I don't see a solution.
Dave Brach
I found that if I use the eye dropper/needle to transfer properties from a window label to the door label, then it corrects the door label.
