Duplicated Object GUID (Global Unique IDentifier) problem?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-08-05
06:12 PM
2023-05-24
12:30 PM
Rubia Torres
2016-08-05
06:12 PM
To fix objects with the same GUID you open the object and do a save as and tick the little box that says "Make new object" and it applies a new GUID to the object. Only problem is doing the above isn't working for me ArchiCAD 20.
Is there another way I can fix this?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-08 11:58 PM
2016-08-08
11:58 PM
If you go to the Library Manager Dialog, and select the library of the object, then duplicate the Library Part there, does it still cause this duplicate issue?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-17 03:50 PM
2016-08-17
03:50 PM
Hi Laszlo
I tried duplicating one of the objects as you said and saved it into the Embedded Objects. Once I reloaded the libraries it did not list the embedded one as being a duplicate. Weird
Should I repeat for the other duped objects and save them out to their respective libraries?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-17 03:55 PM
2016-08-17
03:55 PM
Yeah, it is weird.
But if it works, just do it.
