a week ago - last edited a week ago by Laszlo Nagy
Just about done With my new window.
I am adding the same code to my cabinets, doors, door panels, Closet shelving etc!!
and it works great with my wall accessories!
a week ago
How is it's interaction with the host walls in 2D and Sections? The GS macros do so many nice things, but they also fall over for so many things too...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
a week ago
I currently have a few options to display different parts via projections, or just the base window with some lines depicting overhead or transom windows.
I use my wall covering for all my sill detail so the 2D is still pretty rudimentary but it's all there, the window has a sill and casing, although they need work still. I'm just excited to have the dynamic sizes working lol
a week ago
All of the arrays. Do you just have null values merge with the value above / to the right of them?
a week ago
Each value can be modified as long as one is the remaining distance.
Or maybe I'm not understanding your question?
Thursday
Just wondering how your array works. For example, in a 3-3 grid, if 1-1 and 1-2 are merged as one larger panel next to a regular, is this stored as a 1/0/1? And when you expand the number or rows or columns it just copies the values in the previous row or column, overriding the toggled cell with a 1?
Thursday
It has default settings that get set when the arrays are enlarged, but each row is independent so when a row shrinks below the max horizontal number then all the data past the rows array value don't get used and or get reset
