2015-04-27 02:30 PM
2024-06-06 07:15 AM - edited 2024-06-06 07:16 AM
You are using the parameters incorrectly.
You need to be checking for the value of the parameter.
For a boolean it is 1 or 0 (on or off).
For a text parameter you need to be using the value typed into that text parameter - in tour case "SB"
2024-06-06 07:24 AM
That's great, thank you for that.
2024-06-06 09:23 AM
For the boolean, you do not actually have to put the value, you can just write "IF [parameter] then". Using this same notation, you can utilise it within sums, usually to decide whether or not to add a value.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
