Edit Multiple Points of Polyline
pbg
Is it possible to edit multiple points of a polyline while leaving others unchanged? For example move all of the points within the red box to the right while keeping their relationship to one another (within the red box) the same? The remaining 3 control points on the left would stay in their current location. Any ideas on how to accomplish this would be much appreciated! Thank you so much.Screenshot 2023-04-17 065102.png
AC 26/28 USA (latest build) - Windows 11 - Intel i7 - 64 GB Ram - NVIDIA RTX A4000
Here's a short vid showing how: https://capture.dropbox.com/yre0hGmTLpFYbkOM
I think the step you might be omitting is that you have to click on a starting point that is on the line.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
4 REPLIES 4
Aaron Bourgoin
Marquee Tool?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
When I use the marquee tool to highlight those points and move them, it moves the entire polyline - am I missing something?
Thank you!
Thanks so much for the video! I knew I was missing something...
Beautiful. Much appreciated.
pbg
