Elements merge in 3D;
I have one specific question. Im modelling some basic shapes (box), that are same dimensions and material.
I need to see them in 3d with their own outlines, not to bee merged.
4 object : How they appear in 3d :
Guru
Use different materials? This can just be a duplicate of your selected material.
Ling.
Carstenem
you need to cheat, leave a 0.5mm gap between the boxes, this btw if you would render these boxes as glass prevents a double face too. Double faces can cause render problems.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
