2017-03-27
06:03 PM
- last edited
4 weeks ago
Aruzhan Ilaikova
2017-03-27 10:45 PM
another Moderator
2017-03-27 11:20 PM
2017-03-28 11:14 AM
2017-03-28 11:27 AM
2023-04-13 03:35 PM
Both of the issues here still remain in AC 26.
The elevator car can only be shown on the one storey that it is "parked" on. It shows as a hidden line on the stories above and below if you change the visibility settings to "All Relevant Stories". There should be a way to see it as a solid line on every storey.
Also, you can give the elevator a shaft wall, which is nice, but you cannot edit anything about this wall. It would be nice to change the material etc. Why is it so limited and can't behave like a normal wall?
Seems like drawing everything elevator related is best done in 2D.
Cool.
2023-06-07 03:54 PM - edited 2023-06-12 02:37 PM
Welcome to the forum, and don't worry; we're here to help! Regarding the visibility issue of the elevator on different floor plans, you should check the settings of the elevator object in ArchiCAD 20. Make sure it's set to be visible on all relevant floor plans. You can explore the software's detail options for the elevator shaft walls. If you can't find what you need, you can manually create the shaft walls. As for detailed guidance, consider reaching out to Hin Chong. They're experienced in elevator installation and could provide valuable insights and assistance.
