2026-05-19 09:26 PM - last edited on 2026-05-20 08:21 AM by Barry Kelly
maybe this needs to be a wishlist item, but how do we extract/open a .libpack? It seems that the extract library function in archicad is still only limited to .lcf, even though archicad is 2 versions removed from .lcf libraries. Am I missing something?
Solved! Go to Solution.
2026-05-19 10:07 PM - last edited on 2026-05-20 08:21 AM by Barry Kelly
ok, for those interested, there is a way... via the edit gdl library parts tool bar. It was not added to the file > library menu options though... so #wishlist ?
2026-05-20 08:26 AM
It should be there already if you are using a default Work Environment.
It won't be in the menus if you are using an old WE.
2026-05-20 08:39 AM
Really wish new commands would default to visible...
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
a month ago
I definitely rebuild my work environment every time a new version of archicad comes out... but I will double check this.
a month ago
- last edited
a month ago
@Barry Kelly this is with the AC 29 default "architectural profile 29" w/e applied. Not using my custom w/e, and still do not see "extract library package" as shown in your drop down.
Either you have a different OOTB w/e, or you have a custom w/e that you added this command to.
Alos, the "extract container" option you have highlighted is limited to .lcf; the "extract library package" option should be the one to use; but I do not have that in my work environment, or the out of the box 29 w/e's.
a month ago
I wish there was a "migrate work environment" assistant... to apply all key board shortcuts and custom tool bars, and add new tools/features where applicable. But it is what it is... rebuilding the w/e with each release always gives me the chance to revisit my shortcut list, my tool bars, look at new features, and find areas to improve efficiency
4 weeks ago
It could be the language version.
I have the AUS language and template.
I am pretty sure the default WEs are saved in the program and not the template.
Templates can be downloaded from the Graphisoft website, but I don't think that will help.
You would need to download and install a different language version, but it will be easier to just add the commands to your own WE.
I was definitely loading the default AUS template and using the default WE.
My custom template and WE were not loaded.
Sorry I highlighted the wrong command, it should have been the one below.
Fortunately it is possible to add these commands to your own custom menus and toolbars.
4 weeks ago
- last edited
3 weeks ago
I don't know where there would be any other default work environments. But when I apply the standard 29 w/e, I don't see that option.
I definitely can add it as an option in my custom w/e...
