Learn more
Red
Fiber Insulation Object (adding a fill)
Would adding a background fill to this be an easy add?
Years ago I was into GDL, however, I have forgotten more than I knew...
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
2 Replies 2
David Maudlin
Red:
The 2D script looks pretty simple, I think a rectangular fill (using A and B parameters) should do it. You could add a new parameter for the fill type (instead of hard coding the fill), as well as foreground and background pens for additional controls.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Red
It took a few minutes to get the cobwebs out, but I was able to do that with poly2_b command.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
