Folding doors frame thickness
Strawbale23
Would appreciate if anyone could explain how to change the frame thickness for folding doors
Thanks
AC26
https://www.zendsign.fr/
Lee Hankins
Can you set the panel style to be the French Panel. This one allows you to then set the width of each section of frame, (top, bottom, left and right) and you can split them with a grid. Just set that to 1 horizontal and 1 vertical and you’ll get a single glass pane at the size you want.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
Lee Hankins
Lee Hankins
Great, thanks!
I had not thought of that as a solution.
GS, I love you but you need a kick up the bum for these silly and unnecessary work arounds.
AC26
