Tibor Szolnoki
GDL Object Depository
[Note from Moderator - June 14, 2013:
Dear Talkers,
With ArchiCAD 16 came https://bimcomponents.com, the new object site for ArchiCAD. It has become the main distribution center for objects for the ArchiCAD community. It works with ArchiCAD versions 16 and later.
The GDL Object Depository is still functioning for those using earlier ArchiCAD versions. Those versions do not work with Bimcomponents.com as they don't contain the necessary user interface and code for its integration.
The GDL Depository will continue to be located at
http://archicad-talk.graphisoft.com/object_depository.php.
The only change is that there is no longer a direct link to it from the main page of the ArchiCAD-Talk Forum. Otherwise it is working as before]
Original post follows:
Dear Archi-Talkers,
I’m glad to announce that the GDL Object Depository is now open:
This website provides a forum for Archicad users who want to exchange free GDL objects and texture libraries. GDL Object Depository has two purposes:
Free object download
Free GDL objects, libraries and textures are available for download from an easy-to-understand folder hierarchy for all registered members of the Archicad-Talk forum. As a starter GDL object Depository contains all the GDL libraries that were previously released on the GDL Central website. Note that you have to accept the download agreement before you can start downloading.
Free object upload
Registered users of the Archicad-Talk forum are enabled to contribute to the content of this depository and share their free GDL objects and textures with other Archicad users. For each uploaded element the owner has to provide basic information such as the title, the version and the language of the library. Furthermore a short description and a preview image can be added to every object.
Please post your comments and requests regarding the GDL Object depository functions and features in this thread.
Note: Since the complete content of GDL Central is now available from the Object Depository we decided to close the GDL Central website by the end of June.
Best regards,
Tibor Szolnoki
Product Manager
ArchiCAD Product Management
54 Replies 54
Every time that i try to object depository it says:
Not Found
The requested URL /object_depository.php was not found on this server.
no more suport? or it is other place?, i was trying with:
https://archicad-talk.graphisoft.com/object_depository.php
Probably it was deprecated. The same objects are also on https://bimcomponents.com/ so you should use that site.
lopezfigueroa
Where is now GDL Object Depository?
It is long gone.
As Laszlo suggested, try BIMComponents.
You can access it directly from your object, door, windows settings dialogue when you do a search.
lopezfigueroa
Thanks Barry
