2010-01-28 08:11 PM
2010-01-28 08:20 PM
2010-01-29 01:56 AM
2010-01-29 02:31 AM
Kristian wrote:Yes it is, what makes you think it's not?
Vincon
The object you've attached is not the same one having issues in your error message!
The object you have posted works fine though!
2010-01-29 02:49 AM
2010-01-29 02:57 AM
Kristian wrote:I guess I'm getting an error with that object too, here's the messgae I get on the object I sent:
The error message you put in your write up was "Numeric type expression required at line 4 in the 3D script of file Shelf_16in.gsm" and the object you posted is called 1x2 VT.gsm
It wasn't until after I opened 1x2 VT and had no issues with it that I re-read your message and saw the Shelf_16in mentioned.
2010-01-29 03:02 AM
2010-01-29 03:13 AM
Kristian wrote:Dang, this is bewildering, I have color 54, any other ideas?
Ahhh, in that case all it can be is a missing material in 1x2 VT.gsm mate!
It works fine here on my machine but I have material '54'!
Check the .pln you're currently using has that material and it should all work fine!
2010-01-29 03:17 AM
Kristian wrote:Why do you think the color # is the issue here?
2010-01-29 03:26 AM
