GDL Object error message: "Numeric type expression required
I have an object I made a while back and have never had problems with it, now all of a sudden I'm getting the error message:
"Numeric type expression required at line 4 in the 3D script of file Shelf_16in.gsm"
Does anyone know what this error is, why its occurring and what I can do to fix it?
Here's a screenshot of the 3D script:
18 Replies 18
Here's the object
Vincon
The object you've attached is not the same one having issues in your error message!
The object you have posted works fine though!
Kristian wrote:
Vincon
Yes it is, what makes you think it's not?
The error message you put in your write up was "Numeric type expression required at line 4 in the 3D script of file Shelf_16in.gsm" and the object you posted is called 1x2 VT.gsm
It wasn't until after I opened 1x2 VT and had no issues with it that I re-read your message and saw the Shelf_16in mentioned.
I guess I'm getting an error with that object too, here's the messgae I get on the object I sent:
Ahhh, in that case all it can be is a missing material in 1x2 VT.gsm mate!
It works fine here on my machine but I have material '54'!
Check the .pln you're currently using has that material and it should all work fine!
Dang, this is bewildering, I have color 54, any other ideas?
Why do you think the color # is the issue here?
What does the color # have to do with a "Numeric type expression required at line 4 in the 3D script "?
Hmmmmm that is a little odd!
I don't have 11 here to check that it is an 11 issue but it works solidly on 12 & 13. The only other thing I can think it may be is the last status code, the -1.
You only need to use -1 if you're creating holes in the prism!
Try swapping it out for 15 and see if that changes it.
ie
cPRISM_ topMatl, bottomMatl, sideMatl,
5, ZZYZX,
0, 0, 15,
A, 0, 15,
A, B, 15,
0, B, 15,
0, 0, 15
