‎2004-01-13 12:52 AM
‎2004-01-13 04:47 AM
‎2004-01-13 05:20 AM
‎2004-01-13 05:52 AM
‎2004-01-13 05:59 AM
‎2004-01-13 06:10 AM
Rob wrote:The lamps that come with ArchiLumos (standard ArchiCAD ones, with additional parameters) have the parameters for this, and also can take IES profiles - which are essential if you want to do the real radiosity calculation, regardless of the software used. Maybe you should check with your reseller whether some help can be arranged?
I am trying to make light library part that could understand wattage/type of lamp/lumens definition (as we know them from lightning catalogues) by "twisting" Archicad standard parameters to particular rendering engine param's such as Archicad internal rendering engine or AV_works add-on. Does anybody know the Archicad's internal formulas used for distance_falloff and angle_falloff calculation? Are they exponential or linear functions?
‎2004-01-13 06:21 AM
